whats so wrong about that? people have boosted non-opened over 200k mile ka's and they seem fine, usually its so long as the tune is right then the engine should be fine.Edub1 wrote:190K and you're goint to turbo it without rebuilding. How long do you expect that motor to last?
Run more boost.Chezedik wrote:So, just did the dual exhaust swap, and am making 150 now (no matter what little adjustments I make, sort of) where I was making 180, are we good, or keep playing?
Yep and i'm one of them.........when i had my T25 setup i ran 17 PSI with 230K on my motor and my compression is :TheOne™ wrote:whats so wrong about that? people have boosted non-opened over 200k mile ka's and they seem fine, usually its so long as the tune is right then the engine should be fine.
Wow, you're cool.Chezedik wrote:Eat more ****.
LMFAO....Chezedik wrote:Eat more ****.
17 PSI with a T25 on a KA?The All Mighty KA-T wrote:Yep and i'm one of them.........when i had my T25 setup i ran 17 PSI with 230K on my motor and my compression is :
#1 200 PSI#2 200 PSI#3 210 PSI#4 200 PSI
Don't you have some turbos or a KA to blow up?WDRacing wrote:LMFAO....
yeah, i was a noob at my first setup and i didnt run a Vac. Line to my Wasetgate , so the dang turbo just keep on spoolin........Nismo_Freak wrote:17 PSI with a T25 on a KA?
LOL...
yeah, i feel the same way about that. Like i said, that was my first KA-T setup and it did the job for a while, i'm just sick of having full boost at 2200 RPM's, so thats why i'm going with somthing alittle bigger and i'm only going to run 7 to 10 PSI.nissanfanatic wrote:17psi on a T25 doesn't seem like such a great idea... But hey, if it works...
I personally won't touch over 15psi on pump gas...
