s13sr20chris wrote:yeah, me too. i have heard that it "can" so i make a habit of it.
Not that I've measured it both ways, but I'm surprised it would ever not make a difference. The slower the compression stroke, the more air leaks out during the stroke. Having all the plugs out just gives less resistance to the starter from the other 3 cylinders, but it may not matter if the battery/starter are strong. However, I'm pretty sure having the butterfly valve open is a must. If it's closed, where will the air come from for compression? Need to minimize/eliminate manifold vacuum while cranking, let the engine breathe.
