aroche25 »
https://forums.nicoclub.com/aroche25-u177022.html
Sat Aug 13, 2011 8:07 am
I did a compression test yesterday 90' NA, I did not oil the plugs and this was done at full temp.
Cly 1 175psi
Cly 3 179psi
Cly 5 180psi
Cly 2 160psi
Cly 4 166psi
Cly 6 168psi
Lower the compression across one side and the most in 1 and 2..
I know 183psi Is Perfect
Im doing a 120k Mile Timing Service, Rear Main and Upper Plenum Gasket replacement during winter break, because Im leaving for Gainesville for school this week and do not have the time right now.
What else should I do besides the maintenance mentioned to correct the compression issue?
Thanks In Advance.
