BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Fri Apr 15, 2005 3:23 pm
Well, assuming the engine is stock internally, higher than average compression readings could be from carbon deposits on the pistons. Then again, it could be a bad gauge. Have you tried checking the compression with another gauge?
I suppose you could try running some good old Seafoam (or equivalent...I believe it's mostly Naptha) in the gas tank, but I'd probably leave it alone. You've got even compression across all 4 cylinders, which is great.
I honestly don't know if you'll have detonation problems with a KA-T with compression #'s like that, but I'd really double check them before you do anything drastic.
