eliterit »
https://forums.nicoclub.com/eliterit-u12096.html
Tue Mar 23, 2004 9:52 am
i had done a compression test today, but every 10A fuse i pulled never shut off the fuel pump. I just did a sohc to dohc swap. Anyideas???i ended up doing the compression test with just the coil wire unplugged and i got 177,172,175,171... are these no good readings since there was still fuel pressure?
