Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Fri Apr 08, 2005 6:55 pm
I fixed the CEL, i accidentally unplugged the cam angle sensor when i did the compression test.
anyways, for the test, i did it exactly as the FSM says to, with the engine at operating temp, take the fuel pump fuse out, crank the engine till it dies, remove all 4 sparkplugs, put the tester in cyl-1 and hold the throttle wide open while you crank the engine.I checked each cylinder 3 times just to be sure, every time 200 psi.I talked to a friend tonight that said it might be carbon build up. I don't know, this is the first time i've ever heard of having compression numbers that were too high.
