boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sat Jan 31, 2004 3:43 pm
Well, since I volunteered to pick-up ca18det_boy (Aaron) from the airport at 10 this evening, I got bored and decided to give the car a compresion test. On a cold engine, cylinder #1 gave me 160psi (not bad, right), cylinder #2 gave 90psi (ouch, wtf), cylinder #3 gave 145psi, and cylinder #5 gave me 145psi. So I put some oil in #2 and the compression went up to 100psi. Si I decided to put the new spark plugs in and started the car up. It ran rough for a few seconds bnecause I never disconnected the main injector harness which cause theinjectors to spray while checking compression, fludding the cylinders. Finally, it smoothed-out! I watch the vacuum return to 20hg at 800rpm, but I was looking for it to be lower because of a possible broken ring-land or burned fire ring. After the engine hit normal operating temperatures, I did another compression test and all 4 cylinders were sitting smack at 150psi.
All the old spark plugs looked better than any that I've seen in a stock CA18DET from japan (I'll add a pic of them later). The spark plugs that were in there are BCPR6E-11 and I think that this thing is CA18DE plug or something from an SR20. Someone please confirm this as I don't have the time to research right now. The plugs I'm using now are NGK PFR5G-11. Any comments on the actions of this motor would be greatly appreciated. I know motors, but this just spooked me the fook out. Needless to say, the engine idles and revs just fine!
Dee
