nrcooled wrote:As far as turbo seals go you can just send your turbo off to a shop to have it rebuilt and while your at it have it bored out and put in a bigger compressor wheel
1. Turbo Rebuild- $200-2502. Bore and Bigger Compressor- $250-3003. More HP from the t2small- Priceless
As for the valve seals you will have to dismantle the head to get to them but not a super hard job. Just make sure you have every single torque spec (i.e. FSM) so the job goes smoothly
So far from my excessive searching I have found that turbo rebuild will cost about 400.00, where can I find it for 200.00
If I get a bigger bore and compressor would I need to alter anything on my fuel system?? or ECU?
When I disconect the turbo from the coolant and oil lines do i just cap them or do I need to drain the systems??
