tyrodtom wrote:I thought I made it clear a compression test WILL NOT blow a headgasket. The pressures inside the combustion chamber with the engine running ,( you know, spark, fire, explosion) is much much greater than just turning the engine over with the spark plugs out, no spark, no fire, no explosion.
Before you took the plugs out the first time, did you clean out around the spark plugs before you removed them ? When you dropped the 2 plugs, did you check them good enough to see they didn't have something in the electrode area , dirt, small gravel, etc. ? If no on either question, then you might have something loose in the combustion chamber, you put in there.
You might pull the plugs out, turn the engine over, it might find it's way back out the open spark plug hole, or blow in the open spark plug hole with compressed air.
I was just saying if something blew or maybe its just coincidental that it happened during the compression test because beforehand Ive been having overheating problems with the ac on. So I did consider a blown gasket. yes I know that there's no combustion thats why Im thinking of what went wrong. doing the same mistakes can screw my engine up again.
Nope I didnt clean around the plugs when I removed them but I did clean the 2 plugs thoroughly. I dont want to cause any further damage so I wont try turning the engine over. I'll just have to wait until I open the engine. I'll keep you posted.
robt95240 wrote:something else you might check is when dropped the plug that you may have put a hair line crack in one of them that would cause it to arc in the head n not get a good fire through the plug causing it to miss n have a bit of a knock.. id definitely be checking into the plugs or debri in the cylinder anytime i drop a plug i replace it completely cause a tiny crack can cause the weirdest problems
yep next time I'll replace my plugs if dropped
