jasenpeters »
https://forums.nicoclub.com/jasenpeters-u257107.html
Tue Apr 06, 2021 1:46 am
1995 - Nissan Pathfinder - XE-V6, Manual (4WD design, but no 4WD)
All,
Had an accident during the recent (2021-Feb/Mar) ice storm here in ATX.
Slid across MoPac and busted up the front/rear passenger wheel components.
Namely, as the title says, I need to start with the Compression / Tension Rod (name, according to repair manuals).
Sheared it right in half.
I'm having trouble finding a replacement online.
I just want to be sure, before going with a Nissan dealer, that there is or is not a more reputable (or well priced) alternative elsewhere.
My local quote was about $105+ (per rod) from the dealer.
Also, any recommendations for the remaining components up for consideration:
- Strut / Shock Absorber
- Lower Link
- Upper Link
- Torsion Bar Spring
These items are all general components of the front suspension/steering, and it may require a complete rebuild (no problem, come what may).
I understand that there may be many more sub/supporting components necessary.
Thanks.
- Front Passenger Wheel
- 20210401 - FrontPassWheel.png (566.97 KiB) Viewed 1308 times
- Sheared Compression Rod
- 20210401_ShearedCompressionRod.png (564.66 KiB) Viewed 1308 times
- Rear View - XE-V6
- 20210401 - Rear.png (531.39 KiB) Viewed 1308 times
