compression
cys19
Will slapping a turbo kit on a ka24de wear the engine out more than the sr20det? Sr's compression ratio is 8:5 while the ratio for the ka is 9:1. Comparisions please; I'm a newbie.
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
You wont be able to run as much boost with the ka. The lower compression on engines built for turbos is so they can run more booste safely.
SeVa-S13
Car: '05 GTO 6spd
Good tuning will allow to run more boost than most people think the "truck engine" is capable of. That .5 of compression isn't the world.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
oh nooes. high compression go boom.
No, kidding. Take a look here and see what can be done on a stock ka with good tuning.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Good tuning and strong internals will help you run highboost with a high compression cars. I think that the E-55 runs 11:1 compression supercharged. I will have to check.
[Zero-S]
Good gawd!
On pump gas??
Cold_Zero
The 1.8T that Audi and VW uses runs 9.5 to 9.3:1 These cars make 150-180hp. And the E55 AMG has 10.5:1 compression.
Cold_Zero
His question was "Will slapping a turbo kit on a ka24de wear the engine out more than the sr20det? Sr's compression ratio is 8:5 while the ratio for the ka is 9:1. Comparisions please; I'm a newbie."
To answer your question, adding forced induction to a motor not designed for it will have a greater likelihood of engine wear. So will modifying your engine, abusive driving and not maintaining your engine. Engine wear and the ability to safely run boost are two separate questions. You can run boost on any engine you want, but you will have reliability issues and longevity issues depending on how you do it and how the motor is setup.
cys19
So let's take a 544whp SR and compare it to a KAT with all the same type of mods the SR has. Say it also reaches 544whp or higher. Will the KAT wear out faster than the SR with all other things constant--same driver, etc.?
klattr1
Car: GT42R powered S14/KA
is using a thicker metal headgasket to lower the compression ratio considered part of a stock motor?this is what some of the higher hp SR guys have done. Try it out with the KA. Anything thicker than 1mm should do.
