Compression
ZwhiteshadowZ
I have very low compression in #'s 2,4 does any one know why these 2 cylinders would have low compression?
gyfer
make sure engine is it operation temperature before you check it.
what's the number ?
ZwhiteshadowZ
#1. 160 #2. 30 #3. 120 #4. 30 .... any ideas?
Stuntman240
Car: 91 coupe
rings? scratches on cylinder wall? valves stuck? could be an no. of things
ZwhiteshadowZ
how would i be able to tell if vavles are bent w/o takin off the head.... if each one looks like its comin up right could it still be bent?
gyfer
KA24E or DE ?
Try to add some oil into the cylinder, through your spark plug hole.If you see efficeient amout of compression increase(after putting the oil), you have a bad piston ring.
Is interesting you have both 2 and 4 in 30psi. But the #3 is 120 ? that's not good...
