C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jan 17, 2004 5:57 pm
You may want to make sure no air is leaking past the seal on the gauge either. Try putting some oil on the O-ring that seals to the spark plug opening. I had a problem getting consistent readings when I was using a leakdown tester until I did this. I could hear the air coming back out of the spark plug hole.
However, it seems odd that all 4 cylinders would have this kind of problem and consistenly at that. When I did my leakdown, some sealed fine and others did not. And some leaked more than others. Once I used the oil, all sealed fine. I would suspect the gauge.
