S13 240SX »
https://forums.nicoclub.com/s13-240sx-u35182.html
Mon Dec 12, 2005 2:34 pm
I"m rying to look for compression numbers what they should be for the sohc ka.... this is all i could fine...
Measurement of Compression Pressure
1. Warm up engine.2. Turn ignition switch off.3. Release fuel pressure (See How to Change Fuel Filter)4. Remove all spark plugs.5. Disconnect distributor center cable.6. Attach a compression tester to No. 1 cylinder.7. Depress accelerator pedal fully to keep throttle valve wide open.8. Crank engine and record highest gauge indication.9. Repeat the measurement on each cylinder as shown above.Note: Always use a fully charged battery to obtain specific engine revolution.
Compression Pressure kPa (kg/cm2, psi) / RPMStandard = 1,236 (12.6, 179) / 300Minimum = 1,040 (10.6, 151) / 300Difference limit between cylinders = 98 (1.0, 14) / 300
10. If cylinder compression in one or more cylinders is low, pour a small amount of engine oil into the cylinders through the spark plug hole and re-test compression.
* If adding oil helps compression, piston rings may be worn or damaged. If so, replace piston rings after checking piston.
* If pressure stays low, a valve may be sticking or seating improperly. Inspect and repair valve and valve seat.
* If compression in any two adjacent cylinders is low and if oil does not help compression, there is a leak past the gasket surface. If so, replace cylinder head gasket.
+++++++++++++++++++++++++++++++++++++++++++++++++++i found that off 240sx.org/faq but it was on a dohc so i'm just checking if the same steps and numbers are the same for the sohc
