Compression Surge Problema.
CkrooK
Car: 240sxSr
If you see my BOV, you can see tha needle is allll tha way screwed down, because of tha P/S res..
And because of all that, when drivin, barley buildin boost, my BOV cannot release fully, pushin tha air back into tha turbo. I have a video of it, but cannot figure out how to post it. When I build 14psi, its fine and releases, but Im not tryin to build boost everywhere I go ha.
Should I relocate tha res. or should I get another BOV?My dad has a FWD SR and his set up is like this.
Should I just do tha same thing, cause if Im gettin a new BOV, I dont wanna spend money on a new hotpipe, I'd rather do this. His pipe was just cut tha length of tha adapter flange pipe, and he used tha couplings and Tbolt clamps, and he runs 17psi daily, so should I be good?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Well, if it worked for you father on a similar engine, why wouldnt it work for you.
CkrooK
Car: 240sxSr
Reliability issues?Im just wonderin.
This will probably be tha plan.
I was thinkin it woulda be a helllla of a lot cheaper if I just got a L shaped vaccuum thingy[Im sorry I cannot think of tha name], that pulls tha piston up in tha BOV so it woulda hit, but I still dont know if it would clear.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Make a new pipe to move the local of the BOV. Its not that hard or complicated. Or weld in another bov somewhere else and run two.
derrick113
Car: '91 Hatch SR, '93 Vert
or cut your pipe on both sides of the bov then use couplers, similar to the 2nd pic.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
WOW.... this thread was created yesterday........zerothread/271293
Relocate the resevoir + it looks better IMO
CkrooK
Car: 240sxSr
Well if it had a write up that would be splendid.
