Compression #'s, timing guides, and engine pics
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gs14racer
Ok so while im waiting for the transmission id thought id check out a couple things on the motor. First thing this motor hasnt been started in about 7-8 weeks.
Here goes
Drivers bank 150 - 155 - 162 - 180
Pasng. bank 170 - 140 - 155 - 155
So i think maybe the rings are stuck from sitting so long So i pour a cap full of marvel mystery oil down each plug hole and let it sit for about 2.5 hours
Then i recheck
Drivers bank 180 - 210 - 190 - 190
Pass Bank 180 - 180 -180 - 180
Think this is ok guys?/?
Next thing pulled off one of the valve covers, looks pretty clean for a high milage motor
Lastly decided to check for timing guide replacements so removed the pass side cam gear cover and sure as **** found peices of it, though the motor has great oil pressure and ran great before so im pretty sure no damage was done.
Hogg
Hey man,
I just compression tested my motor - and all cylinders are +/- 3 of 160...
It sounds low to me, Id rather have much higher than that - whats this mystery oil stuff? Is it similar to the "Engine Restorer" stuff that you buy in a can?
Sure looks like it proved its value to you atleast hehe!
What was your oil pressure runnin at as well man? Im curious to know - I think mines 45PSI last time it was checked
Modified by Hogg at 8:33 PM 4/6/2007
Return to “VH45DE / VK45DE / VK56DE Forum”
