Compression Rod Replacement
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Nadia
Car: G35 Coupe 2004
So I noticed my car pulling to the right, even after an alignment. I took it to the dealership and they said alignments fine but there is a problem with the compression rod and its covered under warranty - they will replace the right one next week. Has anyone had this problem and did replacing it help? I found this service bulletin on it (03 and 04 coupes and sedans 2wd)-
http://www.infinitihelp.com/Ow...8.htm
ugaexploder
Car: 2007 Lakeshore Slate G35S
interesting, i've never heard of this before. what dealership do you go to in atlanta?
Nadia
Car: G35 Coupe 2004
Just started going to the one in Marietta since I work up near there now and they seem pretty good (but I've only been twice) so far..although their car wash sucked. I used to go to the Infiniti of Gwinett frequently for oil changes on my old car.
joe603
Car: 2014 Durango R/T
I've heard of the compression rod thing...Not sure if there is a recall or maintenance action on it...
I bought my car from Infiniti of Gwinett...lol Infiniti of south Atlanta (union city) is closer though.
C-Kwik
Looks like they are just using their own terminology for one of the lower suspension arms. Since the G35's use 2 lower ball joints to extend the pivot point out further, calling it a lower A arm may not be appropriate.
G_whizz
Car: 2010 G37 Coupe Sport
You frick'n ninja....where ya been der boi???
C-Kwik
still here man...
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
