Compression / Rings
240sxinlv
Hello,
180 165 180 180 (+/- a bit, you get the idea)
1997 80,000 miles. 5000 miles since 5-6 psi Greddy Kit w/ic. Does not burn a drop under normal/spirited driving. Maybe a little after a LONG highway trip or a day at the track....like 1/2 a quart....and thats after 3000 miles.
Goes up to about 200psi with a cap full of oil on #2. Not sure if I did it right. How long do you wait after pouring the oil down?
So its the rings on #2.
Do rings get worse exponentially or linearly?
As long as I keep a good tune and good oil can I expect another 50,000 miles or 5 miles?
I know 165 and 15psi off from the other cylinders isnt the end of the world...I was just hopeing I had the magic engine that would last for ever.
