PapaSmurf2k3 wrote:do a thread search for seafoam.
You can buy it at NAPA. pour it through the brake booster hose, and it will clean the crap out of everything... and make a really huge smoke cloud in the process. You dont have to take anything apart on the motor, except disconnect the brake booster hose. It is reccomended you replace the spark plugs and O2 sensor after you do it though.
Ok, i did the seafoam stuff and i got a pretty descent size of white smoke for about 2 minutes worth...
I dont have the oem O2 sensor, i have my wideband sensor in its place and the bottle said that the stuff is o2 sensor safe... If it went bad then ill just buy a replacement one (no big deal) I have a new set of lugs anyway to replace if these went bad...
I was just curious to know how long b4 i can do another compression test on this motor... Its been about a good 30 minutes since i shut the motor off after dropping in the seafoam stuff...
