Compression results for a f'd up KA
doctorj240
Car: Black s14 w/ redtop
I've come to the conclusion that detonation probably killed her at the tuning session and its gotten progressively worse since then. In any case I have a new engine sitting waiting to be installed so I can build this one. Hopefully in a couple months I'll have a built block.
Dry#1 = 150#2 = 0#3 = 30#4 = 40
Wet
#2 = 30#3 = 90#4 = 90
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
...too...much...timing.
Sorry to hear. Get a stock one back in, and be a little less agressive with the tune...you'll be good to go in ~8hrs or less!
- Brian
doctorj240
:: orion :: wrote:...too...much...timing.
- Brian
Oh yes, I know. From the first run to the last run we had to back timing off about 12 degrees. After the tuning session I started getting a lot of blowby leaking out my intake and it just got progressively worse. So a $100 stock one is going in. I also have a reason to go buy a cherry picker. :)
