Possibly, If you also had it bored. Average decking is usually no more than .010"-.015" (total block and head). Enough to remove a cc or two from combustion chamber. Your in that ball park id imagine.SMoKeM240 wrote:if i put in 9.1 pistons, got the head surfaced, like avg. surfaced and the block decked, what would my comp be around, i was told 9.8
Let us know how it runs...I'm really curious. I miss my N/A KA. That thing was fun...do you have any other head work done (port and polish, oversized valves, cams, etc etc)? What about exhaust/header/CAI, etc. Anyway...update?91StanzaPusha wrote:Hey you guys. I'm curious as to what the compression ratio will be when i'm done mating the de head to e block. I've heard different things and all the compression ratio calculators are showing 12.5 to 1!!! I'll be done on tuesday when i get back from dc and it took me a total of 2 days work! i cant wait.
I believe it is obd-2, my 95 altima was.91StanzaPusha wrote:right now i'm trying to see if my ecu will pick up the altima distributor so i can start the damn thing. By the way, was it in 95 that the altima changed to OBD-II if so then thats probably why it wont read that distributor i got.
