evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri May 16, 2008 6:24 pm
might want to check those numbers by a service manual, and the block casting is just forward of and below the drivers engine mount, the N47 bhead came on 77-80 N42 blocks, low compression dished pistons, if you want to do a build try finding an 81-83 F54 flat top block, this with an N42 head will get you about 9.5:1 and is a very popular setup, plenty of these around on the cheap definitely worth picking them up, if you want to go thogh the trouble of a build spend a couple hundred more and start with better parts
