Daunttless »
https://forums.nicoclub.com/daunttless-u116.html
Wed Aug 07, 2002 8:23 pm
You may wish to go look at the other post you put up. : )
Raising compression is done by changing your combustion chamber. Basically, Higher compression ratios produce more power, up to a point. The more you compress the air/fuel mixture, however, the more likely it is to spontaneously burst into flame (prior to the spark plug igniting it). Higher octane gasolines prevent this sort of early combustion.
The easiest way to raise compression on a DE: Put in KA24E pistons. I think each piston is about 40-50 dollars a piece, putting you at about 200 new from Nissan motorsports. However, your block has to be taken apart to do this, and while you block is apart I'd suggest a rebuild kit ($300-400) to replace all your gaskets, seals and rings, I'd also suggest boring the block to 90mm if you are going to buy the pistons, might as well go slightly overbored.
As far as gains, intake/headers/exhaust and 11.1:1 compression ( 8.6:1 KA24E pistons ) will put you over 200 horsepower. I don't know the exact power output, but it will be around there. However, unless you do the work yourself it will be expensive. You'll need the pistons and rebuild kit, you'll need machine work, boring out your cylinder walls, and while they do that you might as well port and polish your head. Several hundred dollars there, several hundred for the pistons, 350 or so for the headers, 200-500 for the exhaust, dependant upon what you get, and 400 for the rebuild kit. If you have someone else do the rebuild, expect a lot of hours in labor. All in all expect like 2000 dollars. : ) You'll be pushing over 200 Naturally Aspirated horsepower, but it does come at a price unfortunately. You'll also be pretty much topped out unless you go hardcore N/A power which would cost even more. However, you will have a fresh engine to work with, with 0 miles on it. The downside is that you can't go turbo because of the compression ratio. The other downside is you'll hit a wall, and wont' be able to easily increase power. This is why most people go turbo. Good luck with everything, the only truly necessary part is the pistons and rings, and you can get stock KA24E pistons that will fit your block if you take it apart and do it yourself. Good luck! Let me know if I missed anything, I'll update. : )
