pablo_max »
https://forums.nicoclub.com/pablo-max-u67854.html
Wed Jun 27, 2007 4:12 pm
Ok.. here is the latest.
I took your advice to check that the injectors were even firing..I used a stethoscope to listen first on the back three and heard nice click click click but there was nothing at all going on with the first three. So I used a volt meter on the plugs to see if there was any voltage at all. Zero on the first three and .3 or so on the backs. Now just for further poops and giggles, I took off the 1st three plug wires, not really any difference at all. There is a slight difference because even with no fuel it would still burn the EDR gases. Now, when i take off any 1 of the back 3, it just about dies right away. So, I cant say with 100% certainty that it is the ECU, but I can imagine what else it would be. I did take that sucker out and there was some water damage on it. I could see that some of the components were basically shorted out because of all the crap on there. I may try and replace the damaged parts, but I think they will be hard to locate. I dont have a wire diagram for the ecu, so I dont know which pins control the front 3 injectors...anyone know that???I was thinking I should just jumper on to the connector assembly in the ECU to see if the pulses are coming at all. Does anyone know any other reason at all that the front three injectors would not get the pulse before I drop 200.00 on the new ECU?? Please guys, I need some advice on this one.Thanks a lot.Patrick
