Compression question
Touchdown038
Car: Computers, cars, sports
So when I rebuilt my motor this summer I had the machine shop deck the block and also smooth out the head for flatness... he said he had to take off 4/1000" off the head. I thought no big deal...
Well it's started pinging occasionally. Not too bad, just under heavy throttle.
Could this be because the decking/milling (is that the term?) increased the compression, making it so my motor won't like 87 octane crap? Or is it another reason?
For what it's worth, most of the typical sensors are new, except the MAF and the TPS. Both are assumed to be working correctly. Also, putting in 89 gas helps it a bit.
Anyone?
Chezedik
Car: 1991 Nissan 240sx
You dropped the head, and therefore raised compression. However, your stock comp is 8.6:1 so it shouldn't be a big deal. The thing to remember is that Nissan rated HP the same from 89-90. So I would suggest finding a 90 ECU and seeing if that fixes it. You will likely find that you will lose power but also ping. Anyone else have a comment?
BadMojo
Car: 2007 Mazdaspeed 3
I'm pretty sure that Nissan didn't intend for the KA24E or KA24DE to run on 87 octane. When you say that 89 octane helps a little, does that mean you are still getting detonation on it?
Have you tried running 91 or higher octane?
Touchdown038
I drove home (350 miles) yesterday on 92 octane (for some reason, midgrade was 92 at a station in eastern WA), and it did ping a little bit, but not really too bad at all. Only going uphill under medium throttle.
I was under the impression that only the DE was meant to use premium gaso, and the E could use whatever... I might be wrong though, someone correct me on that.
Chezedik
Since you seem to ping when engine load increases, I would try a proper injector cleaner, and maybe back timing off a little. Also, it is possible that your head has been lowered more than once. You can use whatever on either. It says that 'for maximum performance' use premium.
180fan
Car: 89 fastback
Dunno, my old KA24E ran fine on 87. I suspect there are other things causing it. Have you checked the timing?
Chezedik
If the E is like the DE then changing timing is not done by accident. It is easy to mess up distributor timing, but changing base timing is the key. Still, all things considered, do check your timing with a light.
Touchdown038
Checked it today, it's at about 17 degrees... I'm gonna set it at 15 tomorrow and see if that helps. The injectors could possibly be dirty, seeing as how they came with the old engine and I dunno when they were previously replaced. I would really doubt that the head has been lowered more than once, so I'll try the cleaner (I run it occasionally) and try messing with the timing as well.
Chezedik
No, what I was suggesting with the injector cleaner was that the combustion chamber might have some carbon build-up that is heating up and causing ping. But bad atomization can cause ping, too.
Touchdown038
I would really doubt that the combustion chamber has major enough carbon deposits to cause ping already, since I just rebuilt it 4 months ago... but there's always a chance I guess.
Chezedik
Yeah, 4 mos probably isn't enough time. I would say check the timing.
s13sr20chris
considering the small compression increase i would say that is not the prob. i believe you have a air/fuel or ign problem. drive it under load to where its pinging for a good while. while its pinging really good, shut the motor off and coast to a stop. hop out and pull plugs. note the condition.
also, are you using good plugs? whats the heat range?
Chezedik
What would he hope to see?
s13sr20chris
maybe one plug is damaged or defective. shoot i dunno. it could show which cyl is messing up.
Chezedik
Fair enough.
Touchdown038
They're new plugs, not sure of the heat range but they're stock NGKs looked up on the computer at Napa. Don't remember the number exactly... I could try this and see if there's any deposits or anything I suppose...
Chezedik
They should be BKR5E-11, if you would like, you could go to the BKR6E-11. This could help your ping problem.
s13sr20chris
yeah, 6 is good. the idea is that you want to see what the plug looks like while its pinging. the plug will clean itself up after that. i read that trick in an oldschool honda hop up book a long time ago. i have never used it but its been in my back pocket just waiting.
S13inBatnRuge
Car: 93 240sx
will the bkr6e-11 work for the ka24de motor?
