Compression procedure
max240se
Car: 95 240sx
hi all, first of all, i recently acquired this s14 se...this car rocks.....mine is stock form all around but i like the way this car handles the curves and turn.
now to my request.....could someone please post a cylinder compression write-up???
thanks for the help.JB
onosqv
Car: '92 240sx Vert
everyone get's 1 free help from me... cuz I'm nice like that.
zerothread?id=100769
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
Thats for a leakdown test, a compression test is a lot easier. The leakdown test isnt really needed unless you get low compression test numbers.
steps,
1 Relieve fuel pressure/ disable fuel system:pull your fuel pump fuse. (it's labled in your under-dash fusebox)After the fuse is pulled, start the car... it might idle for a second then die out.
2) pull all the spark plugs
3) hook up the compression tester and crank the engine over a few times
4) repeat step 3 for all cylinders, don't forget to record your readings
I believe compression should read out around 179psi.
If compression numbers are under 150, or there is a difference of more than 10-15psi, there is something wrong.
If your compression numbers are high, you have carbon buildup. Run some seafoam through.
max240se
Car: 95 240sx
hey, thanks for the quick reply!
max240se
Car: 95 240sx
thanks for the reply too....but don't i have to disconnect something in the distributor????
onosqv
Car: '92 240sx Vert
Bronze MFP wrote:Thats for a leakdown test, a compression test is a lot easier. The leakdown test isnt really needed unless you get low compression test numbers.
"Why settle for plain when you can be crunchy?" .
O, just a thought: shouldn't you hold the gas pedal at WOT when cranking - otherwise your readings may be lower than they actually are? I just remember that from a while back when I was doing mine.
onosqv
Car: '92 240sx Vert
max240se wrote:thanks for the reply too....but don't i have to disconnect something in the distributor????
I think that's covered in "pull all the spark plugs" - that way you car doesn't actually start when you crank it... At least that's what I did.
Bronze MFP
DOH, yeah hold pedal at WOT... i forget to do that when I actually do my comp. test too... sheesh
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
yeh, wot is a must, unless you like looking at 125 ish psi all day
Bronze MFP
lol, yeah 125 is about what it turns out to be. I find that out the hard way every time I do a comp. test
