IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Jun 25, 2004 7:01 pm
i was messing around trying to figure out the static compression ratio of the vh45 motor with 14 psi of boost.
165.64 is what i came up with for actual compression for the vh45, but the service manual states 185 psi standard.
the equations i found like to use 14.5 psia for atmo., but im at sea level, and i like to use 14.7
so, what your saying is that the equation above [ratio^1.1 x atmo.] is really just to compensate for adiabatic expansion from compression.
what i was getting at is theorectically [100% VE], a vh45 at 14 psi of boost, WOT, and an efficient intercooler, the static compression would be 28.7psia x 10.2 = 292.74 + 14.7 = 307.44 psig
since the motor doesnt run at 100% VE constantly, that would be close to the cylinder pressure at 4000 rpm.
did i figure that correctly?
also, what is the cam overlap with the VTC engaged and disengaged? is there an easy way to disable the VTC actuator?
