Why do you expect 250-ish when the FSM shows a standard of 180 psi and a maximum difference of 14.5 psi between each cylinder? Maybe I'm not understanding the procedure that was done for compression, but yeah the leakdown percentages do look like they're on the high side.skillzilla wrote:Those are both actually pretty weak honestly. I would expect 250-ish and no more than 10% leakdown on any cylinder. Its cool for the place to have done it for you, but I wouldnt pay for it IMHO. Just that little bit of smoke at WOT will piss you off. Then again it was a cold motor like you said, so it may get more decent once warmed up.
not really, but they do change based on the last time the motor was run and how stuck the rings are from sittinglilskyline240 wrote:do leak down test results change depending on if the motor is warm/cold?
