s13_maJiK »
https://forums.nicoclub.com/s13-majik-u80959.html
Fri May 23, 2008 11:25 am
Make sure engine warmed up otherwise readings will be off, but be careful don't have the engine too hott otherwise you can damage your head by removing and installing plugs
Step 1 remove Spark plugs
Step 2 diable spark and fuel (remove fuel pump relay and disconnect connection to ignition coil)
Step 3 install gauge and crank the engine over
Step 4 Take 4th reading from the gauge and compare it to stock specs
