Compression Check on the ol KA reveals...
Nismo_Freak
Car: 89 Nissan 240SX
123k does = wear on motor... imagine that!
Cyl. 1 : 167Cyl. 2 : 166Cyl. 3 : 162Cyl. 4 : 168
Stock : 179 Rebuild Spec : 151
I guess the loss in compression is the culprit to the slow times at the track.
zachosz
Car: NONE!!!
at least it's pretty even
MAXIMUS Nismo
Car: 95 240sx SE
how do u do a compression check? Anyone have detailed inf? Let me go check the Technical boards.................................
1dollar240
Go to your local auto parts store and buy a compression tester for 20 bucks, or better yet, borrow one from a friend. remove the spark plugs and you will probably want to remove the fuse for the fuel pump, insert correct end of compression tester into the spark plug hole, turn the motor over once or twice and the gauge should read what your compression on that cylinder is, move on to the next cylinder and repeat.
1dollar240
PS, what do you mean by rebuild spec- Is that the point at which you rebuild the motor? Im gonna test my newly rebuilt motor in a day or two, I will post the results.
Daunttless
Yes, theres several determining factors for when a motor needs to be rebuilt burning oil, low compression, extremely high mileage, etc. : )
Nismo_Freak
crank the motor around 4 times per cyl. BTW
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
hehehe yeah rem its a compression reading you want not vaccume :)
Mayhem_J30
Car: Ummm...My Car
i would almost rather not know what the compression is due to fear of paying the HIGH DOLLA PRICE to repair. ironically i do have a brand new never been used compression tester sitting in the garage.
Zebrahead
Car: cars, basketball, girls, fishing
Mayhem_J30 wrote:i would almost rather not know what the compression is due to fear of paying the HIGH DOLLA PRICE to repair. ironically i do have a brand new never been used compression tester sitting in the garage.
Send it to me. I'll use it. Haha.
Nick.
Exar-Kun
Car: 2005 350Z
I'll give you five dollars for it.
-chet
MAXIMUS Nismo
Car: 95 240sx SE
thx for the info guys. I learn something new everyday.
