pwjm »
https://forums.nicoclub.com/pwjm-u142925.html
Fri Sep 18, 2009 5:16 pm
1990 240sx, KA24E 50,000 km's on rebuild, 187,000 on chasis
The car was running a little rough before and idle, nothing too bad, just the odd missfire once every 30 seconds or so. I figured it just needed a tune up.
anyways, I was checking the compression on the motor today and it all checked out fine. 150 across the board
however after putting all the plugs and wires back, the car ran like a three legged turtle. running on 3 cylinders at idle, and smoothing out past 2500 rpm. if I jabbed the gas it was a clear and evident missfire. While idling I pulled the plugs one at a time to determine which cylinder was acting up... Number 2.
I could see the spark jumping from the plug wire, so I've got spark. Compression just checked out fine... I thought it must be the injector!
The injector on #2 had been leaking a little, but not that bad really. To determine if it was the injector I swapped it for the #1 and put everything back. engine ran really bad at first till the gas started flowing proper again, but now it idles a little high (900 or so) and it still runs like crap when I get on the gas. Worst of all.. #2 is still missing consistantly.
any ideas? ECU? Dizzy?(can't really see that being the prob) injector harness?
I'm completely stumped. I'm going to do another comp check tommorrow to make sure I didn't bugger up a valve or something somehow.
