S13240 »
https://forums.nicoclub.com/s13240-u302.html
Sun Sep 03, 2006 10:40 pm
Make sure you warm up the engine first then do your compression test. Anything below 126 or was it 128 psi is bad(minimum values per fsm). Pretty much the engine is a goner(needs rebuild).
Max is 156 psi or 160 psi...can't seem to remember...accidentally formatted my hard drive the other night and still haven't downloaded a fsm yet.
Anything numbers higher than that, you probably did it wrong or have a magical engine.
