Yes, I chose to go with supertech pistons because I'm only planning on running 8-12 psi in boost. The car is a convertible, so I don't plan on constant hard driving. Just want a little more power when I need or want it
. When I get a hard top, I'll go much better bottom end for the beast within.
As for the knock, I don't think it's the chain, because it only knocks on a cold startup or after it's been setting for a bit. I'm assuming the oil pump is worn out and looses prime. That was my guess. It actually started when I was low on oil one day and didn't notice it. So could be damage in the valve terrain. That's something I'll just have to tear apart and see. Could be valves out of adjustment now.
As for my build I'm planing
T25 or t28 turbo
Stage 2 BC Cam
Eagle Rods
Super Tech pistons
Stock Crankshaft w/ ACL rod and main bearings
SR injectors
I haven't decided on how the tune would be done yet, I might just ship my ECU off and have it done or I might try something like nistune. Still not sure.
