I realize that. I'm just saying that boosting hi comp engine is not good and that higher boost is a better/safe way to get more power.car nut wrote:I'm pretty sure he's asking about bumping up his compression ratio as opposed to pushing more psi through his turbos.
It's easier to install bigger turbos than it is to pull apart your whole motor and install higher compression pistons.
i think he might be talking about the compression of his engine (i.e., 150+ is a decent compression) as opposed to the compression ratio...he does mention "rebuilding" his engine and not having enough compression, which causes me to think he has a low-compression engine, piston rings, valves, etc. just a guess.car nut wrote:I'm pretty sure he's asking about bumping up his compression ratio as opposed to pushing more psi through his turbos.
No I was trying to say that whats the best compression ratios to run some high psi??vulcanrush wrote:i think he might be talking about the compression of his engine (i.e., 150+ is a decent compression) as opposed to the compression ratio...he does mention "rebuilding" his engine and not having enough compression, which causes me to think he has a low-compression engine, piston rings, valves, etc. just a guess.car nut wrote:I'm pretty sure he's asking about bumping up his compression ratio as opposed to pushing more psi through his turbos.
typically, on pump gas such as 93 octane, i've seen people run up to 18psi.jlmotor1 wrote:No I was trying to say that whats the best compression ratios to run some high psi??
