Compressing valve springs?
cmoody2006
Car: 1993 Nissan 240sx vert
http://www.nicoclub.com/articles.php?id=203057
How do you compress the valve spring to replace a damaged valve?
LayNLow240
Car: 92 240 coupe
For KA24E or KA24DE? either way, this will work for both. AND it will work with the head on the car. But have fun replacing a valve with it still on the block :pIf its for the E you can get the cheaper one that looks like this:
cmoody2006
I'm working on a spair head that broke an exhaust valve... So where can i find one of those at? WIll like advanced auto have them? I know i can see 2 springs one inside the other.... Its also on a sohc
cmoody2006
I'll be doing this tomorrow so any more info would help.... I might do a writeup on this later along with pictures if i can find my camera
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
any auto parts store should have them. You might want to see if they rent valve spring compressors out. That'll save you some moolah. I work at a Schuck's (CSK Auto) and we rent them out. I'm pretty sure autozone does too if there aren't any CSK's around. Pay the deposit, use it, return it for a full refund. Absolutly no charge to the customer apon return.
wa-chiss
2005 Toyota Sequoia
Also, is the head of the valve bent or the stem? If stem then you probably wont be able to remove it. But if it's just the head then you probably good. Just cut a piece of a straw off and slide it over the stem. That way you don't score the inside of the guide when removing it. Get as thin a straw as you can.
cmoody2006
No the valves aren't bent the head i'm going to use has had a valve crack and it messed up the piston but the head is fine. The head i have now is being a pain in my aS$ i went to drill out a bolt that snapped off and it ****ed up my head so i've got good valves in both heads i just need to swap 1 valve to the newer head.
