Comprehensive List of Recall's and TSB's (Also links to ALL Infiniti vehicles)
AddictionG35
Car: 2003 Infiniti G35 Coupe 5AT (R.I.P. 03 SEP 07)
We've had more than a few people asking lately about the G's and any problems with them, so I have compiled a comprehensive list of recalls and TSB's (most 03-04 G's) and included links for ALL other Infiniti Vehicles.
Recalls/Campaignshttp://x.infinitihelp.com/foru...id=88
TSBshttp://x.infinitihelp.com/foru...id=63
Service Manualshttp://x.infinitihelp.com/foru...tid=3
Diagnostic helphttp://www.infinitihelp.com/Ownership/
Maintenancehttp://x.infinitihelp.com/maintenance/
Owners Manuals and Guideshttp://x.infinitihelp.com/foru....html
Here are 6 major recalls. Nature of Defect:1. FUEL:FUEL LINES:HOSES:NON-METALLIC Recall Number: 02V245000Dates Manufactured: JAN 2002 to JUL 2002Number of Vehicles Affected: 18300Date Owners Notified On: SEP 2002
Vehicle: 2003 Infiniti G35Defect Description:THE FUEL HOSE CONNECTION FOR THE OUTLET OF THE FUEL PUMP WHICH IS LOCATED AT THE TOP OF THE FUEL TANK MAY NOT HAVE BEEN PROPERLY ATTACHED WHEN THE VEHICLE WAS ASSEMBLED AND COULD COME LOOSE WHILE DRIVING OR WHEN STARTING THE ENGINE.Consequence of Defect:IF THE CONNECTION COMES LOOSE WHILE DRIVING, THE ENGINE WILL STOP RUNNING DUE TO LACK OF FUEL, INCREASING THE RISK OF A CRASH. ALSO, IF THE CONNECTION COMES LOOSE WHILE DRIVING OR ATTEMPTING TO START OR RESTART THE ENGINE, SOME FUEL WILL DISCHARGE FROM THE FUEL PUMP. IF THIS SHOULD OCCUR IN THE PRESENCE OF AN EXTERNAL IGNITION SOURCE, A FIRE COULD RESULT.
Nature of Defect:2. EXTERIOR LIGHTING:HEADLIGHTS Recall Number: 02V331000Dates Manufactured: N/A to N/ANumber of Vehicles Affected: 36000Date Owners Notified On: JAN 2003
Vehicle: 2003 Infiniti G35Defect Description:SEDANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-***246; IN THE ASSEMBLY OF THE HEADLAMPS, IT IS NECESSARY TO HAVE A MEANS TO ADJUST THE HEADLAMPS. TAMPERPROOF CAPS TO PREVENT HORIZONTAL ADJUSTMENT OF THE HEADLAMPS ARE THEN INSTALLED. SOME OF THESE VEHICLES ARE MISSING THE TAMPERPROOF CAPS.
Nature of Defect:3. SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT Recall Number: 03V200000Dates Manufactured: AUG 2002 to MAR 2003Number of Vehicles Affected: 60000Date Owners Notified On: JUN 2003
Vehicle: 2003 Infiniti G35Defect Description:ON CERTAIN SEDAN AND COUPE MODEL VEHICLES, THE BRAKE STOP LAMP SWITCH MAY MALFUNCTION.Consequence of Defect:IF THIS OCCURS, THE BRAKE LAMPS WILL NOT ILLUMINATE WHEN THE BRAKE IS APPLIED, WHICH COULD RESULT IN A CRASH WITHOUT WARNING.
Nature of Defect:4. ENGINE AND ENGINE COOLING Recall Number: 03V455000Dates Manufactured: JAN 2002 to JUN 2002Number of Vehicles Affected: 630000Date Owners Notified On: N/A
Vehicle: 2003 Infiniti G35Defect Description:ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.Consequence of Defect:THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Nature of Defect:5. FUEL SYSTEM, GASOLINE Recall Number: 05V555000Dates Manufactured: NOV 2001 to OCT 2003Number of Vehicles Affected: 192659Date Owners Notified On: N/A
Vehicle: 2003 Infiniti G35Defect Description:ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.Consequence of Defect:FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.Corrective Action:DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Nature of Defect:6. EXTERIOR LIGHTING Recall Number: 06E060000Dates Manufactured: N/A to N/ANumber of Vehicles Affected: 87745Date Owners Notified On: N/A
Vehicle: 2003 Infiniti G35Defect Description:CERTAIN AAI MOTORSPORTS COMBINATION LAMPS SOLD AS REPLACEMENT LAMPS FOR USE ON THE ABOVE LIST PASSENGER VEHICLES. COMBINATION LAMPS NOT EQUIPPED WITH AMBER SIDE REFLECTORS FAIL TO CONFORM WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-***246;Consequence of Defect:LACK OF AMBER SIDE REFLECTORS IN THE LAMPS WILL DECREASE LIGHTING VISIBILITY TO OTHER DRIVERS AND MAY POSSIBLY RESULT IN A VEHICLE CRASH
Here are 77 TSB BulletinsComponent Description:
1. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06004Bulletin Date: MAR 2006Vehicle: 2003 Infiniti G35Summary:MALFUNCTION INDICATOR LAMP WITH DIAGNOSTIC TROUBLE CODE U1000 OR U1010 STORED IN ENGINE CONTROL UNIT. 2002 - 2006 INFINITI VEHICLES WITH CAN COMMUNICATION. ( NHTSA ITEM NUMBER - 10019293 )
2. SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR Bulletin Number: 03056ABulletin Date: NOV 2005Vehicle: 2003 Infiniti G35Summary:ESSENTIAL TOOL J-45741-INF ABS ACTIVE WHEEL SENSOR CHECKER. ( NHTSA ITEM NUMBER - 10006124 )
3. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002Bulletin Date: NOV 2005Vehicle: 2003 Infiniti G35Summary:CLICKING NOISE FROM REAR AXLES. ( NHTSA ITEM NUMBER - 10017773 )
4. SEATS Bulletin Number: 02080Bulletin Date: JUL 2005
Vehicle: 2003 Infiniti G35Summary:DRIVER'S SEAT NOISE AND/OR ROCKS BACK AND FORTH. ( NHTSA ITEM NUMBER - 10016401 )
5. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002Bulletin Date: JUL 2005Vehicle: 2003 Infiniti G35Summary:CLICKING NOISE IS COMING FROM THE LEFT AND/OR RIGHT REAR AXLE WHEN ACCELERATING FROM A STOP. ( NHTSA ITEM NUMBER - 10016567 )
6. STRUCTURE:BODY Bulletin Number: 05034Bulletin Date: JUN 2005Vehicle: 2003 Infiniti G35Summary:NOISE FROM REAR DOOR WITH WINDOW ALL THE WAY UP. ( NHTSA ITEM NUMBER - 10015415 )
7. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020Bulletin Date: MAR 2005Vehicle: 2003 Infiniti G35Summary:TRAILER LIGHT WIRING. TO INCLUDE INFINITI 2006 M35/M45. ( NHTSA ITEM NUMBER - 10012880 )
8. STEERING Bulletin Number: 03028ABulletin Date: SEP 2004Vehicle: 2003 Infiniti G35Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10005686 )
9. STRUCTURE:BODY Bulletin Number: 03052Bulletin Date: SEP 2004Vehicle: 2003 Infiniti G35Summary:SQUEAK AND RATTLE REPAIR.COUPE ONLY. (NHTSA ITEM NUMBER - 10003435)
10. VISIBILITY:REARVIEW MIRRORS/DEVICES Bulletin Number: 04046Bulletin Date: SEP 2004Vehicle: 2003 Infiniti G35Summary:RATTLE NOISE FROM REAR VIEW MIRROR HARNESS COVER. ( NHTSA ITEM NUMBER - 10009749 )
11. STRUCTURE:BODY Bulletin Number: 04035Bulletin Date: AUG 2004Vehicle: 2003 Infiniti G35Summary:RATTLE NOISE FROM REAR SIDE WINDOW FINISHER. ( NHTSA ITEM NUMBER - 10009175 )
12. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 04042Bulletin Date: AUG 2004Vehicle: 2003 Infiniti G35Summary:NAVIGATION SYSTEM IS INOPERATIVE AND THE DISPLAY SHOWS DISC ERROR OR DVD-ROM VERSION IS NOT CORRECT. ( NHTSA ITEM NUMBER - 10009182 )
13. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS Bulletin Number: 04033Bulletin Date: JUL 2004Vehicle: 2003 Infiniti G35Summary:WINDOW REGULATOR MOTOR RESET PROCEDURE. ( NHTSA ITEM NUMBER - 10009364 )
14. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 04024Bulletin Date: MAY 2004Vehicle: 2003 Infiniti G35Summary:SUNROOF LID SQUEAK/CREAK NOISE. ( NHTSA ITEM NUMBER - 10007679 )
15. INTERIOR LIGHTING Bulletin Number: 04019Bulletin Date: APR 2004Vehicle: 2003 Infiniti G35Summary:VANITY MIRROR MIRROR BULB REPLACEMENT. ( NHTSA ITEM NUMBER - 10007728 )
16. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020Bulletin Date: APR 2004Vehicle: 2003 Infiniti G35Summary:APPROPRIATE HOOKUP POINTS FOR CONNECTING A TRAILER LIGHTS WIRING HARNESS TO THE VEHICLE. ( NHTSA ITEM NUMBER - 10007727 )17. ELECTRICAL SYSTEM Bulletin Number: 03055Bulletin Date: FEB 2004
Vehicle: 2003 Infiniti G35Summary:BUZZ SOUND FROM METER CLUSTER AFTER IGNITION KEY IS TURNED OFF / TURN SIGNAL AND WARNING CHIME DO NOT SOUND. THIS REPLACES ITB03-055 DATED 8/20/03. ( NHTSA ITEM NUMBER - 10003514 )
18. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03069ABulletin Date: JAN 2004Vehicle: 2003 Infiniti G35Summary:REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE. THIS BULLETIN REPLACES ITB03-069. ( NHTSA ITEM NUMBER - 10005216 )
19. STRUCTURE:BODY Bulletin Number: 03050ABulletin Date: JAN 2004Vehicle: 2003 Infiniti G35Summary:SQUEAK AND RATTLE REPAIR. SEDAN ONLY.( NHTSA ITEM NUMBER -10005687)
20. STRUCTURE:BODY Bulletin Number: 03052ABulletin Date: JAN 2004Vehicle: 2003 Infiniti G35Summary:SQUEAK AND RATTLE REPAIR.COUPE ONLY.( NHTSA ITEM NUMBER - 10005688 )
21. EQUIPMENT Bulletin Number: 04001Bulletin Date: JAN 2004Vehicle: 2003 Infiniti G35Summary:REMOTE KEYLESS ENTRY REPLACEMENT PARTS. ( NHTSA ITEM NUMBER - 10005194 )
22. STRUCTURE:BODY: DOOR Bulletin Number: 03071Bulletin Date: DEC 2003Vehicle: 2003 Infiniti G35Summary:RATTLE OR CREAK NOISE FROM TOP OF DOOR WINDOW FRAME. ( NHTSA ITEM NUMBER - 10005263 )
23. INTERIOR LIGHTING Bulletin Number: 03065Bulletin Date: NOV 2003Vehicle: 2003 Infiniti G35Summary:CLOCK BULB REPLACEMENT. VARIOUS MODELS INCLUDING 2004 I35. ( NHTSA ITEM NUMBER - 10004598 )
24. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058BBulletin Date: OCT 2003Vehicle: 2003 Infiniti G35Summary:POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10004562 )
25. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 03060Bulletin Date: OCT 2003Vehicle: 2003 Infiniti G35Summary:SUNROOF INOPERATIVE. 2004 FX35/FX45 INCLUDED. ( NHTSA ITEM NUMBER - 10003951 )
26. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056ABulletin Date: SEP 2003Vehicle: 2003 Infiniti G35Summary:NOISE FROM ENGINE AREA WITH AIR CONITIONER ON. ( NHTSA ITEM NUMBER - 10003595 )
27. ELECTRICAL SYSTEM Bulletin Number: 03020BBulletin Date: SEP 2003Vehicle: 2003 Infiniti G35Summary:MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003916 )
28. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058ABulletin Date: SEP 2003Vehicle: 2003 Infiniti G35Summary:POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10003913 )
29. SEAT BELTS:FRONT Bulletin Number: ITB99016BBulletin Date: AUG 2003Vehicle: 2003 Infiniti G35Summary:FRONT SEAT BELT LATCH PLATE RETAINING BUTTON MISSING. VARIOUS MODELS INCLUDING THE 2004 G35. ( NHTSA ITEM NUMBER - 10003519 )
30. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017ABulletin Date: JUL 2003Vehicle: 2003 Infiniti G35Summary:REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10003437 )
31. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023ABulletin Date: JUL 2003Vehicle: 2003 Infiniti G35Summary:RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10003457 )
32. SEATS:MID/REAR ASSEMBLY Bulletin Number: 03046Bulletin Date: JUL 2003Vehicle: 2003 Infiniti G35Summary:A CREAK / SQUEAK NOISE FROM REAR SEAT AREA. ( NHTSA ITEM NUMBER - 10002937 )
33. STRUCTURE:BODY Bulletin Number: 03050Bulletin Date: JUL 2003Vehicle: 2003 Infiniti G35Summary:SQUEAK AND RATTLE REPAIR. SEDAN ONLY.( NHTSA ITEM NUMBER - 10003454 )
34. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 03045Bulletin Date: JUL 2003Vehicle: 2003 Infiniti G35Summary:NOISE FROM ENGINE AREA OR AIR CONDITIONER NOT COLD DUE TO BROKEN DRIVE BELT. ( NHTSA ITEM NUMBER - 10002936 )
35. ELECTRICAL SYSTEM Bulletin Number: 03020ABulletin Date: JUN 2003Vehicle: 2003 Infiniti G35Summary:MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003351 )
36. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 03026Bulletin Date: JUN 2003Vehicle: 2003 Infiniti G35Summary:NAVIGATION SYSTEM STUCK ON PLEASE WAIT SCREEN. ( NHTSA ITEM NUMBER - 10003335 )
37. SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER Bulletin Number: 061003Bulletin Date: JUN 2003Vehicle: 2003 Infiniti G35Summary:SEAT HEATER HARNESS VOLUNTARY SERVICE CAMPAIGN REPAIR INSTRUCTIONS MODIFICATION. ( NHTSA ITEM NUMBER - 10002087 )
38. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 03020Bulletin Date: APR 2003Vehicle: 2003 Infiniti G35Summary:MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10002202 )
39. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023Bulletin Date: APR 2003Vehicle: 2003 Infiniti G35Summary:RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10001445 )
40. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03021Bulletin Date: APR 2003Vehicle: 2003 Infiniti G35Summary:GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS. ( NHTSA ITEM NUMBER - 10001677 )
41. STEERING Bulletin Number: 03028Bulletin Date: APR 2003Vehicle: 2003 Infiniti G35Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10001676 )
42. ELECTRICAL SYSTEM Bulletin Number: 03007ABulletin Date: MAR 2003Vehicle: 2003 Infiniti G35Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001253 )
43. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017Bulletin Date: MAR 2003Vehicle: 2003 Infiniti G35Summary:REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10001256 )
44. SEATS Bulletin Number: 03018Bulletin Date: MAR 2003Vehicle: 2003 Infiniti G35Summary:DRIVER'S SEAT COMFORT IMPROVEMENT. ( NHTSA ITEM NUMBER - 10001258 )
45. ELECTRICAL SYSTEM Bulletin Number: 03007Bulletin Date: FEB 2003Vehicle: 2003 Infiniti G35Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001246 )
46. ELECTRICAL SYSTEM Bulletin Number: 03014Bulletin Date: FEB 2003Vehicle: 2003 Infiniti G35Summary:SLIP AND VDC OFF LIGHTS ON WITH C1145 YAW RATE SENSOR STORED. ( NHTSA ITEM NUMBER - 10001249 )
47. ELECTRICAL SYSTEM Bulletin Number: ITB03007Bulletin Date: FEB 2003Vehicle: 2003 Infiniti G35Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001162 )
48. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074ABulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE (DTC) P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000971 )
49. POWER TRAIN:MANUAL TRANSMISSION Bulletin Number: 03003Bulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:MANUAL TRANSMISSION SHIFT KNOB NOT STRAIGHT. ( NHTSA ITEM NUMBER - 10001026 )
50. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006Bulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:SQUEAK OR SQUEAL NOISE COMING FROM REAR BRAKES. ( NHTSA ITEM NUMBER - 10000972 )
51. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006Bulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:REAR BRAKE NOISE. ( NHTSA ITEM NUMBER - 10001181 )
52. STRUCTURE:BODY:ROOF AND PILLARS Bulletin Number: 03004Bulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:HEADLINER SAGGING AT REAR OF SUNROOF. ( NHTSA ITEM NUMBER - 10001027 )
53. EXTERIOR LIGHTING:HEADLIGHTS Bulletin Number: 03001Bulletin Date: JAN 2003Vehicle: 2003 Infiniti G35Summary:VOLUNTARY RECALL CAMPAIGN - HEADLAMP ADJUSTER CAP INSTALLATION. ( NHTSA ITEM NUMBER - 10001023 )
54. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074Bulletin Date: DEC 2002Vehicle: 2003 Infiniti G35Summary:AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000019 )
55. INTERIOR LIGHTING Bulletin Number: 02081Bulletin Date: DEC 2002Vehicle: 2003 Infiniti G35Summary:INTERIOR COURTESTY LAMPS INOPERATIVE. ( NHTSA ITEM NUMBER - 10000795 )
56. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02010ABulletin Date: NOV 2002Vehicle: 2003 Infiniti G35Summary:ENGINE WILL NOT START. VEHICLE IMMOBILIZER SYSTEM/NISSAN ANTI-THEFT SYSTEM (IVIS/NATS). ( NHTSA ITEM NUMBER - 10000406 )
57. WHEELS Bulletin Number: 02073Bulletin Date: NOV 2002Vehicle: 2003 Infiniti G35Summary:TITANIUM FINISH ALUMINUM WHEELS. ( NHTSA ITEM NUMBER - 10000411 )
58. EQUIPMENT:ELECTRICAL Bulletin Number: 02072Bulletin Date: NOV 2002Vehicle: 2003 Infiniti G35Summary:AMBIENT TEMPERATURE SENSOR DISPLAY INACCURATE. ( NHTSA ITEM NUMBER - 10000410 )
59. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02064Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:REPLACEMENT AUTOMATIC TRANSMISSION REQUESTS NEW STYLE AUTOMATIC TRANSMISSION FLUID FILLER TUBE. ( NHTSA ITEM NUMBER - 10000213 )
60. SEAT BELTS:FRONT:BUCKLE ASSEMBLY Bulletin Number: 02067Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:FRONT SEAT BELT BUCKLE BRACKET CAUSING CLICKING NOISE. ( NHTSA ITEM NUMBER - 10000212 )
61. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Bulletin Number: 02062Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:AUDIO MATRIX. ( NHTSA ITEM NUMBER - 10000215 )
62. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE Bulletin Number: ITB02056Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:INFORMATION REGARDING A BUZZ OR GROWL TYPE NOISE FROM THE ENGINE AREA WITH THE AIR CONDITIONER ON WHICH GOES AWAY WHEN THE AIR CONDITIONER IS OFF. ( NHTSA ITEM NUMBER - 635644 )
63. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. ( NHTSA ITEM NUMBER - 10000216 )
64. ELECTRICAL SYSTEM:BATTERY Bulletin Number: ITB02055Bulletin Date: OCT 2002Vehicle: 2003 Infiniti G35Summary:INFORMATION ON COUPE BATTERY SERVICE PRECAUTIONS. ( NHTSA ITEM NUMBER - 635643 )
65. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02054Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) STORED IN THE ELECTRONIC CONTROL MODULE (ECM). ( NHTSA ITEM NUMBER - 10000130 )
66. STRUCTURE:BODY Bulletin Number: 02060Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:CREAK NOISE FROM FRONT END. ( NHTSA ITEM NUMBER - 10000132 )
67. SUSPENSION Bulletin Number: ITB02060Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:SOME VEHICLES MAY EXHIBIT A CREAK NOISE FROM THE FRONT END WHILE DRIVNG OVER ROAD DIPS, RAIN CHANNELS, STREET INTERSECTIONS AND / OR DRIVEWAYS. ( NHTSA ITEM NUMBER - 635647 )
68. STRUCTURE Bulletin Number: 02028ABulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:CREAK OR RATTLE NOISE FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 10000129 )
69. STRUCTURE:BODY: DOOR Bulletin Number: 02057Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 10000131 )
70. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028ABulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:INFORMATION PERTAINING TO A SQUEAK, CREAK, OR RATTLE NOISE COMING FROM THE CENTER OF THE DASH OR BOTTOM OF THE WINDSHIELD WHILE DRIVING. ( NHTSA ITEM NUMBER - 635640 )
71. STRUCTURE:BODY: DOOR Bulletin Number: ITB02057Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:INFORMATION ON DIAGNOSING POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 635646 )
72. OTHER Bulletin Number: ITB02054Bulletin Date: SEP 2002Vehicle: 2003 Infiniti G35Summary:THIS BULLETIN PROVIDES SERVICE INFORMATION FOR MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) STORED. ( NHTSA ITEM NUMBER - 635642 )
73. STRUCTURE:BODY: DOOR Bulletin Number: ITB02021ABulletin Date: JUL 2002Vehicle: 2003 Infiniti G35Summary:CONCERNS WITH RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 635047 )
74. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Bulletin Number: ITB02017Bulletin Date: APR 2002Vehicle: 2003 Infiniti G35Summary:SUBJECT REGRDING TRANSMISSION CONTROL MODULE (TCM) INITIALIZATION AFTER TRANSMISSION REPLACEMENT. ( NHTSA ITEM NUMBER - 632216 )
75. STRUCTURE:BODY: DOOR Bulletin Number: ITB02021Bulletin Date: APR 2002Vehicle: 2003 Infiniti G35Summary:SUBJECT REGARDING RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 631189 )
76. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028Bulletin Date: APR 2002Vehicle: 2003 Infiniti G35Summary:SOME VEHICLES MAY EXHIBIT A SQUEAK, CREAK OR RATTLE NOISE COMING FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 635057 )
77. POWER TRAIN Bulletin Number: ITB02019Bulletin Date: APR 2002Vehicle: 2003 Infiniti G35Summary:CONCERNS WITH TACHOMETER NEEDLE ON WRONG SIDE OF STOP PIN. ( NHTSA ITEM NUMBER - 631192 )
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Good info, I'm gonna sticky until Joe Decides what he wants to do with this...
joe603
Car: 2014 Durango R/T
Nice work Joe!!! I think this deserves a custom title...what would you like?
I'll add it to the G-series FAQ.
AddictionG35
Lol... I have no clue really , hadn't even thought about it to be honest. I'll get back to you?
Or maybe you could surprise.
Modified by AddictionG35 at 8:44 PM 8/14/2008
joe603
No problem! Just e-mail me when you come up with one.
