No, it's silly because...DrifterProdigy85 wrote:its not silliness, your just too ignorant to open your mind to it.
Regaurdless of my opinion, it is interesting. I don't foresee it happening on an SR anytime soon, let alone in an S-chassis, simply because there isn't any room there, not to mention our engines just can't handle huge power unless built to the max with the best parts money can buy. And lets face it, the majority of 240 owners aren't wiping their asses with 100's, let alone 20's. This definitely isn't something for a street car. But perhaps it will be done. I just don't see the point of wasting the time, effort, and money to spool a large turbo 1-1.5k rpms sooner.DrifterProdigy85 wrote:Engine size doesnt make a difference except for what turbo sizes you need to run. Your trying to look at it as the compressor is spooling the turbo. It doesnt work that way. This isnt a supercharger. Turbo needs exhaust velocity. Spooling up the small turbo gets the engines exhaust velocity high enough at lower rpm to spool the big turbo. The intake pipe is setup like that so the discharge of the big turbo goes into the small turbo and is pushed out into the engine. The small turbo is considered the High Pressure Turbo since its being forced air instead of trying to pull it.
http://www.youtube.com/watch?v...edded
Not really cause it depends on how much power your after. I want close to 700hp when im all done so it takes a big turbo to get that. Only way to make it spool faster than it does now is by spraying nitrous, putting it on a larger engine, or doing this compound setup. Being i dont wanna fill bottles and i already have an SR built by Mazworx, the compound setup would be the way to go to have alot of fun. It should give a huge jump in tq than before since the 67mm will be making way more boost at earlier rpm. How much tq is really gonna depend on the cam setup too.jbracy7 wrote:wouldnt better tuning and a better turbo net the same results
No, because then you wouldn't get the compounded boost that is created with this setup, and the larger one would back-spool the smaller one and it would run like crap, if it ran at all on boost. Trust me, it's right. Or don't trust me and do some research, you will find however that it's right, and if you want big power with less lag, it's either this or a vnt setup, which can be just as complex to make it work right.Emperor_Tha wrote:Would make more sense if it had two intake piping instead of the outlet pipe going to the second turbo inlet.
Power comes from the flow rate of the turbo. For 700+hp, you need something that flows 70+ lbs/min. AWD dyno numbers are always horribly inflated. Real numbers lye in there mph at the track which i hardly ever see matching numbers for an AWD car. The EVO and STI are the only cars ive ever seen put down 700+awhp on a GT35R. The turbo only flows 62 lbs/min or something. Everybody else barely gets over 600-650whp with them. And thats with 2 wheels. Graph out the compressor map and you'll see how unrealistic 700whp is on one. Expecially with AWD. 700awhp is like 800rwhp. Its way too unbelievable. I have a 2 step for drag racing it launches pretty hard doing that but lets say you wanna go from a roll @ 45mph. That would put me in 2nd gear at around 4k-4500rpm which even brake boosting doesnt build but maybe 8-10psi at that point. Brake boosting only works if your in the turbos powerband.hugogos22 wrote:I dont really post much any more but this thread caught my eye. You dont really need to have a large frame turbo like a 40R or 42R to make 700HP. You should take a look at billet turbos turbo like the PTE 6765 that have made 820 AWHP on 4G63. The PTE 6262 has made 780 AWHP. These turbos are the same size as my old 35R and have made that power on a T3 Flange. These turbos spool like a 35R but make the power of a 42R. Why worry about a 1000RPM of spool? If you drag race get a stand alone and launch on a two step. If you like to roll race on the street down shift and brake boost.
