Mettler wrote:Has anyone thought about a parallel twinturbo setup per bank, with a big turbo and a little turbo both operating off the same exhaust manifold on each side, both internally wastegated ?
The exhaust outputs would merge, as would the intake side.
The intent is obviously to allow the small turbo to spool just off idle, and the big turbo to supply the major kick in the pants. Of course, the boost periods would need to be tuned to overlap significantly.
http://i162.photobucket.com/al...t.jpg
Any reasons why this would not work ?
With current turbo technology like ball bearing center sections and much better wheel designs, I think a sequential setup is really not needed anymore. I know there are still quite a few big power diesel engines that use a setup similar to that but the way they run is like so:
Manifolds -> small turbo exhaust inlet -> small turbo exhaust outlet -> large turbo exhaust inlet
A better way would be something similar to yours but with a valve that would completely close off exhaust flow to the smaller turbo for the best output and efficiency you can get. Though, like I mentioned above, its really just not necessary with current technology. Even better, when variable turbos start to finally become more common place it would totally remove any need for a sequential setup like that and they could even take the place of the positive displacement s/c's in producing more low end power.
Honeywell (Garrett) is currently working on a variable turbine AND compressor... that will most definitely outperform the superchargers all together. Sure s/c's will still be around due to great reliability (roots) and just due to peoples' personal preferences, but this new turbo will definitely make for some very crazy cars... eventually.
