component speakers
DeeZNuTTss
Car: 240sx 4/1991 hatchback s13
I want component speakers. the only problem is that i don't know if the ones i want fit.
there the Infinity Reference 6000cs 6.5" Component Speaker System
Size 6-½" RMS Power Range 2-90Watts Peak Power Handling 270Watts Sensitivity 92dB Frequency Response 53-21KHz Design 2-way Tweeter Design Dome Tweeter Composition Textile Woofer Composition Injection-molded Poly Woofer Surround Rubber Impedance (Ohms) 4 Dimensions Top-mount Depth 2-1/16"
i know i will have to cut the door some but will it get in the way of the window?oh yeah i have a 1991 240sx s13
thanks guys.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
http://www.nissaninfiniticlub....id=99
:cool:
Chingon
Car: 1991 and 1992 hatchbacks
stock they won't fit. the s14 is a perfect fit however, but the speaker holders on the s13 are 4x7 I think or some weird number like that.
Onizuka
S13 fronts are 4x6inch, rears are 6.5inch. All this info is in the autosection, there is also a great moderator there that can answer any of your questions (for future refrence)
Tweaky_Tom
S-14's got places for the tweets and the 6.5's. I have speaker baffles for the s-14 if you need em. If yer interested just search for "Goodies". <<<Tom>>>
Onizuka
Thats only on s14's with the premium sound option, which alot of s14's dont have supprisingly.
Tweaky_Tom
Nakamichi RULES!
Chingon
J-Spec Tuner wrote:S13 fronts are 4x6inch, rears are 6.5inch. All this info is in the autosection, there is also a great moderator there that can answer any of your questions (for future refrence)
That's odd.. both s13s in my driveway...use the 4x6" on all 4 corners.
mattlord42
Car: 1991 240SX Coupe
It was just the coupes that had the 6.5" reares. The hatches had 4x6 all around.
Matt
Rex
Car: None
As J-Spec Tuner suggested ... Nissan & Infiniti Speaker reference
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
cutting the sheet metal is very easy to do, you can have 6x9 put in in a afternoon.
