1qckser »
https://forums.nicoclub.com/1qckser-u232.html
Fri Jun 27, 2003 4:09 pm
You can get more horsepower out of the Q V8 if you are willing to tear into the engine, If you know someone who can reassmble it correctly, and time it correctly then you are golden, you would be able to do some nice headwork, maybe even do a larger size piston for more compression, like for instance we run the TT300z pistons in our SR20DEs, also IF you could find someone to custom ground some cams for the motor that would really yield some HPs, I think what you would end up with is a motor that would now have a lil bit more tourque, but the hi rpm HP would be sick, Im picking up a spare motor from SOPDADOPE and do think im gonna pull the heads and see what we can do, we have a flowbench and that will help out a ton, bottom line is if you have the cash anything can be done, now you just have to do the transmission , the rearend, and the brakes, and some other stuff to be up to the task, and oh yeah 500 hp for 180K< Im all over that:D
