rogerontherun »
https://forums.nicoclub.com/rogerontherun-u226940.html
Tue Oct 29, 2013 8:35 pm
I have been working on a 2001 QX4 with 197,xxx miles. It has been sitting for a few months, and now the owner has decided to sell it. A week or so ago he went to fire it up and it stumbled and chugged, but made it back home. Eventually it stopped running altogether. I read the codes for it, P0505 and P1140. I told him what they meant, and the 0505 code was more likely the culprit. I went ahead and did my research, then replaced the IAC. Here are where the problems truly begin. It definitely ran again, but had an idle of 1500-2500 rpm. We attempted an idle relearn to no avail. I checked and double checked all wires and hoses I disconnected, then I cleaned out the vacuum hoses for the SCV, sprayed the MAF (with MAF cleaner) and applied dielectric grease. I have checked voltages and resistance in the IAC, TPS and MAF. I am still getting P0505 plus 1130, 1131 and 0171 codes plus dramatically reduced performance and a completely erroneous idle. The idle seems to have a pattern though.. I will start at 1,000 then climb to 2,000 and then bounce from 2,000 to 1,500 6-8 times then go back down to 1,000. All that happens every 45-60 seconds. Since I do not completely understand the whole SCV system (or Nissan engineering for that matter), it's easy for me to point my finger and blame that. The only things I have in mind are a stuck/corroded valve in the SCV system or a plugged fuel filter. I beg of you.. please help me!
