Completely re-wiring my bose - where to get power? dual antennas?
Post all your Nissan electronics, car audio and stereo questions here!
fueler
Car: 2 Nissan's
2 BMW's
Hey guys I am pulling out my bose. I am completely re-wiring to all the new aftermarket speakers. Where should I draw the power from? Splice into the OEM power wire?? How do I hook up these dual antennas to the single input on an aftermarket deck??
ALL HELP IS APPRECIATED
fueler
Car: 2 Nissan's
2 BMW's
Whoa guys don't go running eachother over just to answer my question...
PoorManQ45
What kind of car?
Are you just trying to get the antenna to work?
If so I believe PAC has some options
audtatious
Talking from a 2k2 Maxima here, but should be similar....
You can get an antenna adapter at most audio stores to convert the dual-prong wire to a standard antenna connection. In the Maxima, off the antenna wire is a green wire as well. This green wire needs to be connected to the new headunits power antenna connection since the green wire is used to turn on the factory antenna amplifiers. Without that connection, you will get no AM reception and very bad FM reception.
