completely loosing tracktion at shifting
migsk8
Car: 240sx
ok well i was racing this dude the other day right, it was like at a 5 roll.........well i punched it and shifted at 7.5 and when i did my back 2 tires lost complete traction and my car steered left towards some woods, and i was about to smash the curb and go diving in some woods, when i quickly recovered the car. it was a 3 lane road, so i did a pretty good like 3 to 5 feet of "skidding" when i shifted
i just wanted to know, what would be the cause of something like this, how i can reduce it/ eliminate it
first off, i know my tires aren't that good, but they are just 2 months old, they are just some cheap tires but they have like 90% thread on them
also i do realise the SR has about as much torque as it has hp
third off, i have lsd, so when i lost traction i was def screwed in the rear 2 wheels department?( that would be a queston )
ok so i have an SR redtop, with regular mods, so its pretty stock except for intercooler, fuel pump and stuff like that just in case you wanted to know
Hijacker
Car: '92 240sx Convertible
'94 F-150
Sh1tty tires are sh1tty tires whether they have 90% tread or 5% tread left.
I'm going to suggest next time you "race", which I pray is on a track, ou shift sooner than 7500. You were almost 1000 rpms over the power dropoff of a stock setup. You chirped your tires because there was a dimished load strain being put on the tires, and then you shifted back into the meat f your power band, breaking the tires loose.
I have no clue what kind of lsd you have, Different kinds have different effects on rear traction. A clutch type will keep the rear wheels locked together under load, increasing the effects of your tires' inability to hold traction.
A viscous would have had little effect under load when you broke your tire loose. Once one wheel really gets to spinning on a viscous unit, until you can bring the car under control, there's not much you can do to keep that wheel from spinning.
A helical would have the same effect as a viscous in your situation.
jared36
Car: 89 240sx
Its your tires...no question about it. Not only should you be running better tires on an SR but the width should be at least a 225 if you want some traction. I have some 205/50/16s with -2.4 camber and I have basically the same setup as you andI dont really get traction till 3rd, but thats how its supposed to be for drifting.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
yea when i turned up th e boost ion my car, i lost traction betwenn 1st-2nd-3rd it sucked .lol
migsk8
Car: 240sx
well i r
Hijacker wrote:Sh1tty tires are sh1tty tires whether they have 90% tread or 5% tread left.
i raced him again and i shifted at 7 and it chirped and i still beat him
what do you mean by
" You were almost 1000 rpms over the power dropoff of a stock setup"?
Hijacker
'94 F-150
Stock cams start to loose wind past 6500. Once you pass 7000, you're wasting effort because you've exited the powerband. When I auto-x I shift anywhere between 6500-7000.
