Completely Dead '09 G37x
Ivanci
Car: Infiniti G37xs
This one has me confused and could use some help.
Went through the steering wheel locked problem in July. Was able to navigate that problem. Now car is dead again in driveway. Seems to be related to the rain, as this is second time it's happened.
First time, I replaced the battery. Seemed to take care of the problem, but don't know if it was because the car had dried out or not. This time, the switch stayed in on mode until the battery died. Car never turned over, then the Christmas lights lit up the panel.
Rained all day (car outside) and have 100% charged battery. All accessories engage except for the ignition. Still wet and will have to push car in little later. Have to disconnect battery to take it out of everything on mode. Will not switch to off with button.
Is it possibly a wet connector? Looked around 4-5 forums and couldn't find much.
Thanks in advance...
Ivanci
telcoman
Was your vehicle submerged under water?
Telcoman
