Or, you could just put a quart of oil in it once a week...jasonsan wrote:if you tear it you will need to pull head (it will stick out like a tongue)
my fear w/o the h.g. removed is that the slightest bend on it may screw up the seal to the cylinder head as well as the dummy sprocket being hard to remove. I have this laying around so for now i am removing the upper twp guides and replacing the front crank seal. Then when i get the rest of the parts i wan't to put on saved up i'll do the complete job h.g. and all and just pull the engine to do it.datsun2401972 wrote:well, as far as the gasket surface between the timing cover and head goes, it sees a little pressure built by the combustion process(bottom of pistons going up and down in the crankcase area). Your PCV is supposed to take care of that. But if you ever try to take off your oil cap while running(don't btw) you'll feel a pretty good amount of air spewing it's way around the oil cap(along with oil if your not careful).
That's the force that part of the HG has to put up with...which is miniscule compaired to the pressures the rest of the HG sees...
In addition to that your timing chain is whipping all the excess oil around in the front cover/head area.
The reason the FSM probably states that is because it's easier to work with, with the head off. But like Jason said, just rub a little silicone on the bottom of the HG. More importantly, be careful when putting the front cover back so that you don't make too much of a mess of the front of block/timing cover gasket surface. Once you get it lined up, it's just a matter of tapping in the dowel pins, and your set!
well it isn't my dd but it is the only dependable vehicle i have to go very far out of town other than the wifes car. If it take the wifes car i have to take the kids cause i won't leave her w/o reliable trans in case something happens. I have a 20month old and a 4 month old so you never know. Plus i am the type of person i will repair anything i can while it is apart so i would need a rear main seal, MAy as well do the iav, the knock sensor is in my glovebox waitin, Do machinework to head,replace rack bushings while motor out,do the clutch and flywheel again, put on header and catback so i am thinking of waiting till i got what i need. I have had the car for 8 years and put 100,000 miles on it. It had 56,000 on it when i got in in feb 00 and it made the tin cna noise then but i wan't it to be the way it needs to be.datsun2401972 wrote:iono about the dummy sprocket thing, once again, i've only worked on my single cam.
If you don't bend it, you won't have to worry. I've done it once, so I know I can do it without bending it np...just have a little faith.
But if you have all those parts just sitting, why wouldn't you just take the engine out and redo all those things anyways?
I guess, if it's your DD don't screw with the head, if not, then pull that *****!
