Yikes! That seems pretty amazing to me. Was it loose and stressed by some accident or event?HolySh*t wrote:I'm dropping my car off at the dealership on Monday (they're full Friday and Saturday) to have my right rear shocks fixed. The shop that I took it to initially said that the bolt the connects the shock to the car (behind the seat) snapped in half.
Do you have an Extended Warranty? If not, then you may not be able to get this done free unfortunately - since the time part of the original warranty is over.HolySh*t wrote:Will I need to replace the shocks or should they be able to replace just the bolt? Is this covered under warranty? I just kind of want to know what to expect.
I have a 2003 Infiniti M45 with under 53K miles on it.
Short of going for coil-overs from Japan (maker is called Insurance or some such name - I can look it up if you want), there is no after-market shocks for the Y34 that will fit - at least, nothing that I have found with some searching. Argh!HolySh*t wrote:For those of you replacing your shocks are you going with factory or after-market.
So, you have to do OEM shocks. Cheapest source is http://www.everythinginfiniti.com ... and they ain't inexpensive! Will cost nearly $1k in parts alone.
Z
That is much better news. I guess the bolt is replaceable since it can be purchased. I wonder if the dealership will be honest and tell me that the the entire shock needs to be replaced.GJEMD wrote:bolt is $7.50 rear shocks are $175 each. Should not take more than 1 hr labor to replace both rear shocks. Z must be referring to replacing the front struts as well.
Yes. My estimated cost was for all four shocks. Sorry for the scare!GJEMD wrote:Z must be referring to replacing the front struts as well.
Good idea.HolySh*t wrote:I may get the shocks replaced since i'm nearing 60K. I may hit that around the end of the year.
It looks to me like the center shock rod goes through the center of those two parts mentioned above. I would have thought it was part number 4 that was broken on your car? If so, the shock is probably still fine.HolySh*t wrote:http://www.infinitipartsusa.co...gid=0
The bolt that is broken is one of the bolts that go up through 16 and 13. Do you think I will need to replace the entire shock?
