Complete poly bushing kit
WPGQX4
Car: 1998 Qx4
Does any body make a poly kit that has all the bushings you need to replace on a 98 qx4? Everything I've found has everything seperate. I'd like to buy it all at once so i don't miss anything.
fueler
Car: 2 Nissan's
2 BMW's
i dont know of a kit but www.4x4parts.com sells them all...
theres not a lot... all you have is lower trailing arms, upper trailing arms, and panhard rod. That's like 10 bushings. I did the lowers only and it made a world of difference.
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
what about all the swaybars? control arms? i'm sure they're more bushings?
and I'm not meaning to argue... just probing for more.
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
Lets see, from front to back...
*2 Front Swar Bar Bushings
*2 Sway Bar Links (W/ Poly Bushings)
4 Front Control Arm Front Bushings (2 Per Arm)
4 Front Control Arm Rear Bushings (2 Per Arm)
4 Lower Trailing (Control) Arm Bushings (2 Per Arm)
4 Upper Trailing (Control) Arm Bushings (2 Per Arm)
*2 Rear Swar Bar Links (W/ Poly Bushings)
*2 Rear Swar Bar Bushings
2 Pan Hard Rod Bushings
Did I miss anything?
With the exception of the items marked with an asterisk (*), all of the above mentioned are available on 4x4parts.com. They also recently added a kit containing all 8 trailing arm bushings w/ replacement bolts. Replacing these would likely make the largest difference.
WPGQX4
Car: 1998 Qx4
Thanks Ron. I'll try and see if I can find them all at 4x4.
