Complete Parts Diagram
Vince B
Hello all,I have a 2009 G37x coupe that sustained some undercarriage damage from hitting a brick. I have found some online sources for parts diagrams but none have the exact parts that I am looking for. It punched a hole through the black plastic cover on the passenger side that covers the brake lines etc... Does anyone have a link or know I can ID this part. I have the FSM but it doesn't have the complete exploded parts diagram with part numbers. Any help would be greatly appreciated! Thank you.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
74814-JK000Thats the part number. Its a little pricey. Around $200.
Vince B
WOW that was fast! Thank you so much. I had one more question. I presume you must have access to the exploded parts diagram. I used to have one for my wifes 2003 G35 but I can not locate one for the G37 coupe. Do you know where I can access one online or purchase? The reason I ask is if I had the info myself then I don't have to bother generous people such as yourself for the part numbers. I can look them up myself. Also, I looked at the damage a little closer and found that the RH wind deflector (black rubber piece) right in front of the rear passenger wheel well got damaged too! Thanks again for all your input/help.
zozoka1212
Car: 08 Infiniti G35x
Vince B wrote:WOW that was fast! .
His wife says that all the time to him. LOL
He is Nico certified Infiniti technician.
Sorry Poyzi had to do it.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
Poyzinous
Vince B
Thanks again Pozyi! Do you happen to have the pn for that rubber wind deflector on the rear passenger side. It is located right in front of the rear wheel well. I got ripped/damaged as well. I wonder what those are on there for. I don't remember seeing them on the 2003 G35 coupe.
Poyzinous
maybe you could post a pic because I don't see what you're talking about...
zozoka1212
Vince B wrote:Thanks again Pozyi! Do you happen to have the pn for that rubber wind deflector on the rear passenger side. It is located right in front of the rear wheel well. I got ripped/damaged as well. I wonder what those are on there for. I don't remember seeing them on the 2003 G35 coupe.
Hm is that a wind deflector? Never knew. What happened to the one you had on the car. How did you rip it off? I only seen them on the 07 sedan first.
Vince B
That's what they call it in the FSM. I'll see if I can take one tonight after I get done shoveling the last of the 20 inches of snow in front of my place...
Vince B
I just looked at the FSM and it's located in the " EXT " section of the manual page EXT-27. It looks like they are showing the driver side. I would need the passenger side. It got ripped from the brick that hit the underside of the vehicle.
Poyzinous
76856-JK000its like $13
Vince B
You are the best. I appreciate it. Do you know anywhere I can purchase the exploded parts diagram?
Poyzinous
I dont know anything personally, many body shops have diagrams they either somehow get from infiniti, or a secondary mapping company. I don't know however... I just use the nissan fast system from my computer
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
you can check out
http://www.infinitipartsonline.com
they have a parts catalog you can view to make sure you buy the right part
click on VIEW ILLUSTRATION after you select the part you are looking for.
Vince B
Thanks again for all your help. I really appreciate it!
simphmerj
Car: 2007 G35 6MT
Poyzinous wrote:maybe you could post a pic because I don't see what you're talking about...
hey, poyzi, how about the little piece that clips onto the windshield cowl, and connects the washer fluid tube to the tube that comes off the wiper arm.
edit: it's a 2007 G35 coupe
it's part of the whole cowl.
here's the broken one that i pulled out of the cowl.
the dealer told me i had to get the whole cowl piece for 180$.
is that legit, or can i get just the little connector piece.
thanks,
allan
Poyzinous
that would be a 28937-AQ000.
Your Guy at the dealer must not be very bright
