PullinWrenches »
https://forums.nicoclub.com/pullinwrenches-u310407.html
Sat Aug 12, 2023 1:46 pm
Hello,
Thank you all for your help.
My conclusions were (may not be spot on, YMMV (FYI this truck has a 5 speed (that even when new had trouble pulling top hole due to lack of snoose))):
1. This truck came out during the still early days of mfg's trying to comply with emerging EPA rqmts, was still a work in progress. Not a good transition time maybe, I know they started years earlier but is what it is. This truck has a few critical points of failure due to it's age and lack of parts avail. A few might be TBI injector, carb fuel pressure regulator, distributor/ECU function, distributor/Coil transistor function, there are more.
2. As I understand it the ECU on this truck is pretty busy, it monitors many ancillary (could be bypassed), and some vital things things such as crank angle (from the dist sensor), O2 level, Exhaust Gas temp, throttle body position, engine temp, and it modulates both the amount and timing of fuel squirts and directly sends a firing signal to the Transistors on the coils. The distributor appears to make zero decisions on it's own, it seems to only distribute the high voltage and send crank angle to the ECU. BTW interesting aside, I was always amazed with this engine as it had two spark plugs per cylinder (like a airplane!)! Where in a airplane it is done for redundancy (safety, fired by mags not distrib) in this case the second plug appears to fire only when the engine is cold!?? Blows my mind to think they added a second plug for pollution reasons, but appears they did. Now THAT was not cheap! Also makes it hard to find a replacement distributor although I would be happy to give up one bank of plugs (I believe the exhaust bank are the ones in "normal" use). Amazing to me.
3. I think it is fairly easy to convert this motor to a Weber carbureted motor (replace factory in tank pump with inline 720 low pressure pump rather than new pressure reg, maybe use a aftermarket adapter to turn the carb 90deg, install manual choke and hand throttle if desired, much more). Lot of info out there on this, I think it would be a solid swap.
4. The remaining issue for me then becomes the ignition. When you swap out the carb the ECU will lose some inputs. This part I am not sure of and would depend on the computer algorithm it runs (not knowable I think), but looking at it seems likely the ECU may throw a code and go into some sort of failed state that will put it into some sort of limp mode where among other thing ignition timing advance may not work. I guess I could test that theory but not will to spend time on it. If you want to try just unplug everything from the TBI and see what/if it throws any codes. Although I can find several reports on the inet about this carb swap I cannot really find one that details how the truck then runs over all, but is scary stuff for me. And, I cannot seem to find a replacement distributor with centrifugal advance that will fire the plugs independently, haven't really looked at pre-ECU units, etc. Hard to believe Weber sold all those kits and diminished all those trucks???
As a aside, I have ridden a old Indian MC where you had to set ignition advance manually via a lever on the handlebar, not fun unless you are on the highway. And DO NOT forget to retard the timing before you kick it.
Rock solid truck that I will miss but time to part ways at least for me... and oh, there is that pesky body rust!!!
Again, thank you all.
