Had to search far and wide for info on installing a aftermarket head unit with the bose system so here is what I found that actually works:
Dash adapter: you can use the scoshe or Metra for the same year maximal. Apparently the Metra allows for a caged install and the trim face can still be used. It is supposed to be cleaner. I used the scosche. It turned out pretty well but there are some gaps and the trim face cannot be used.
Harness adapter:
I used the scoshce nn03. Made things easy.
Line level converter:
You have to have this because the bose speakers are individually amped. If you don't reduce the gain you risk blowing the speakers. I used the scoshce fai4. The slc4 and the oem4 will all accomplish the same thing. If your converter has input and output gain adjustment turn the inputs all the way to zero or - and set the converter to factory amp. You can set the gain of the output a few ways. One is to turn the stereo to 3/4 volume and then adjust gain until you get distortion. The easier way is with an ohm meter and you can do this with out power to the system. Measure resistance between the pos and neg speaker wire for each speaker ( grey to grey/black or purple to purple/black) adjust the gain to 2 ohms.
Antenna:
You need a diversity adapter. I used scoshce uaa1. Our cars have 2 antennas, the mast and the window. The adapter cuts out one of them. You have to experiment and see which antenna gives the best reception. Install one way and if you don't get good reception flip the connector around. Beware the connection and the stock antenna wire are flimsy. Don't kink the wire or bend it during install or you'll lose reception. One you have it hooked up tape the connector together. I read all kinds of things about power amplified antennas and having to hook up the power wire. Believe me none of it works. Just find which antenna wire works best and don't kink the wires.
That's it. The stock speakers if in good shape put out some good sound and bass. The head units are crap though.
